vtec not working and high idle popping noise in my intake
trappin_247
Ok so i bought a car and it has a cel i took it to the autoparts and i got code p1259 which is vtec malfunction i would like to know how could i fix that the other little problem im having is that the car idles constantly between 1,700rpms or 1,200rpms i think thats a little high and some times it goes jumps back and forth like if the iacv was bad but it dose it rarely and i also hear a popping sound in the intake once in a while i think it would have something to do with the dizzy but its not a missfire btw its a 2000 civic sedan lx with a swapped d16y8 and auto to
trappin_247
trappin_247 said:
Ok so i bought a car and it has a cel i took it to the autoparts and i got code p1259 which is vtec malfunction i would like to know how could i fix that the other little problem im having is that the car idles constantly between 1,700rpms or 1,200rpms i think thats a little high and some times it goes jumps back and forth like if the iacv was bad but it dose it rarely and i also hear a popping sound in the intake once in a while i think it would have something to do with the dizzy but its not a missfire btw its a 2000 civic sedan lx with a swapped d16y8 and auto to manual
Posted from Clubcivic.com App for Android
2slo4u
wait4me
popping inside the intake????...
do you have enough oil?
make sure the plug is plugged in all the way,
you might need a new solenoid or a new switch
trappin_247
yea I hear a popping noise coming from the intake i feel it might be from the dizzy tho and the oil is fine I don't have any leaks
2slo4u
wait4me
the solenoid will be in the area at the top left corner of your valve cover. it has a brownish color and is being held down by three 10mm bolts.
because it is a swap, has the wiring harness been properly modified to engage vtec or is it using the correct engine harness?
trappin_247
the solenoid is plugged in and it's a ex harness which belongs to the motor but wiring wise everything looks good
2slo4u
wait4me
could be a faulty vtec solenoid or the whole switch
trappin_247
what should my Ecu say for me to know it's a manual ecu i have a p2p a12
2slo4u
wait4me
37820-P2P-A12 99-00 mt ex 2dr/4dr
It's for a manual
