water in trunk, & only driver's side
Puma
Has no filter
Every time it rains the trunk gets wet and a heavy rainfall will cause almost a full INCH of standing water ONLY on the driver's side along the door only. Mind you, the inner door, seat, nothing interior is wet, ONLY the floor.
The seals are fine, we've already checked. All panels line up correctly except for the trunk, which I have a feeling is the issue w/ water leakage back there.
The part that puzzles me is the car was wrecked by a prior owner on the passenger side, and everything is absolutely fine on that side.
Is anyone else having this issue? Any insight is appreciated. I'd love to get this fixed before the interior is ruined, considering my interior is almost mint.
Thanks!
Kelly
Esotericimage
Taking an H-T break
i would get a hose and try to pin point where it is coming from.. Usual leaks are from the sunroof drain or rear tail lights.. but it could be door/window seals or pretty much from anywhere..
Puma
Has no filter
tail lights are dry, no sunroof. all seals are fine. already tried hosing the car down and can't see it. i can HEAR the water but not see it. fml
SwiftEKtuner
EJ6 Powderpuff
where do you hear the water coming from?
durgo
for the driver side floor area it could be your windshield. I had that problem with my truck, had the windshield reset and no more leak. as for the trunk its usually the tails, could be the lid seal or the rear window though.
Puma
Has no filter
the trunk i'm thinking it's b/c it's not set on straight.
it sounds like it's coming from the windshield and trickling down the door jams or something. how in the heck would a windshield become lose but not break?
durgo
Its not necessarily loose, could just be a weak place in the window adhesive that broke down over time.
