Mike's-EM2
So I noticed when I start from a complete stop, I put the car in first, let the clutch out to just before the catch point then I add gas and let the clutch out to the catch point like normal. My problem is for some reason, once I add gas while releasing the clutch, I hear this weird grinding noise. It's not the gears because I make sure I completely shift into all gears. It almost sounds like the clutch is rubbing really hard against the flywheel even though the car is moving. The grinding nose usually stays until I hit about 20mph and it can be heard even after I shift in to 2nd. Any help in diagnosing this issue is greatly appreciated. Thanks.
