freelove33
I just bought a 2000 civic lx with the 5 speed. Car is pretty clean and has 145K on it. It's in pretty decent shape for it's age. I just picked it up last week and have recently noticed a couple things. Number one, and most importantly is that it seems to have a bit of a weird idle/run slightly off. It's mostly noticeable when I'm idling. The RPMs drop and starts to run a little rough.
Starts fine and shows no check engine light, and yes the bulb is fine. The light comes in when you first turn the key. I thought it could just be a misfire but I assume it would throw a code for that. I don't have a scanner to check. Any ideas?
My other issue is my temperature gauge is off and sometimes bounces around.
Cold/off:
Warm:
I'm not as much worried about my gauge since it's seems to be below where it should be cold the same amount as when it would be warm. The engine also gives off no sign that it could be overheating. I appreciate any and all input!
Cold/off:
Warm:
