What are the advantages of a Adj. Fuel Regulator
HYPHYinMy4DR
The titles pretty much says it all.
So whats the main advantage of an adjustable Fuel regulator on a N/A engine.
Other then higher fuel psi.....
DetainedCivic
I haz SR20
adjusting the amount of fuel pressure :shock:
Genuine Rolla
Its PETEY PETE, y0!
would that increase HP or make the engine run lean/rich...?? I would like the know the answer to this as well...:what:
hondaSi_col
i have one fuel regulator...it works cuase you adjust the pressure of the fuel...and keep it constant... when the car needs more gas the regulator give much more...i dont know if i am wrong lol....
weksos
when you are in need of tuning cams/gears or such that requires more fuel.
94exvtec
There really is no advantage if you're running a stock N/A engine. Now, if you have hotter spark, or more camshaft lift, then you can use the regulator to help achieve your stoichometry, or your ideal air/fuel ratio of 14.7:1
Just my .02
