I kept cleaning it but it comes back when I roll it up. I used hand sanitizer l the get it crystal clear. It's not from a bird as it comes from the interior window trim not the outside. Thanks, I'll look up Majestic HondaNever seen that kind of residue being left on the glass like that. You could try cleaning it really well first. Put the window down and use a mild detergent and sponge. See if that makes a difference before replacing it. Maybe just a bunch of bird doo in there or something.
That sort of part you would need to get from Honda though. Check online Honda OEM dealers. Majestic Honda usually has better prices than local dealerships.
My bad on the late reply and yes I definitely see it now. The inner rubber strip is coming up. Should I purchase it from the dealer?Yeah Im dealing with this now if you peel back the rubber strip and inspect it you'll see where its comming from. The inner part begins to wear out and starts rubbing off on your window and messes up your tint if you have any.
Re-read my reply.My bad on the late reply and yes I definitely see it now. The inner rubber strip is coming up. Should I purchase it from the dealer?
I had the same thing and changed out my inner door trim. I ordered them from HondaPartsNow.com or visit any of the several online dealer websites. I believe the outer trim affects that as well from the pressure it applies or lack thereof. On those dealer sites the inner trim ranges in the $30s each but the outer trim is in the $60s each.
Ok thanks. Probably read right past that. I'll look to order some probably this weekRe-read my reply.
