y7 block an z6 head mini me swap
Wreckless Hype
¯\_(ツ)_/¯
I've always thought the rule of thumb was use the water pump for that block. I'm assuming the concern is with keeping up with the extra strain the vtec will be putting on the block?
Th Y8 which is also a vtec setup, uses the same water pump as the Y7, so it should be able to handle a mini me just fine.
As far as the oil pump goes, I know a Z6 pump would work on the Y7, but I think there's an issue with the dipstick lining up. Again, referencing part numbers through Honda sites, the Y7 and the Y8 use the same oil pumps, so I don't see the issue there either.
