Greetings,
I put a ZC in my 89 crx si. It runs great and gets over 30mpg in town with snow tires (Colorado). Unfortunately is failed the emissions test really badly. The HC is always high, so I'll buy a new cat. The original motor ran so much smoke through it that I can believe it's shot. At idle the CO is .3, but jumps to 6.2 at 2500 rpm. When I re-tested, I did it while it was cold. The CO at idle jumped to 3.2, and the 2500 rpm dropped to 2.5. The only thing I can think of that is temperature related is the intake air temperature sensor.
It's running the si ecu, has a new O2 sensor, distributor cap, etc. We kept the si throttle body also. I've checked the fuel injector resistance and it's OK. The fuel rails and injectors are what came with the motor. The plugs are new platinums, but are getting black from the rich fuel mix.
Any ideas on why the mix is so rich and should the IAT sensor make that much difference?
