Tanabe Revel Touring Sport Coilover Sale
Jay Jay
Administrator
Premium
We are running a sale on Revel Coilovers until 6/7/18.
Tanabe Revel Touring Sports Damper Coilovers
EVERYDAY PERFORMANCE
The 32 way adjustable Revel Touring Sports Damper is the ideal solution for the most comfortable ride in a coilover kit while achieving an extremely low ride height and utilizing the perfect balance of dampening forces and spring rates to deliver smooth performance when it is needed.
PILLOWBALL UPPER MOUNT
Pillowball upper mounts give the driver greater driving feedback when compared to OEM rubber upper mounts. A spherical bearing is used in place of a rubber bushing and an adjustable camber plate is utilized on certain applications which aid in achieving improved tire traction and alignment.
*Pillow ball upper mounts included on certain applications.
LOW FRICTION THRUST WASHER
Teflon thrust washers reduce friction during steering movement and eliminates spring binding and movement. Also eliminating unwanted noise and maintaining proper adjustment of the height adjustment.
*Teflon thrust washers included only on MacPherson type strut.
PERFECT BALANCE
Spring rates are perfectly balanced between comfort and sport like feel for optimum ride quality. Full length thread body with independant preload allows for max lowering.
MONOTUBE DAMPER
Larger piston valves and oil capacity allows for a faster reacting dampening force and efficiency through all temperature ranges. High strength and rigidity brackets ensure the driver has the utmost confidence for all driving types.
Shop Online at:
https://www.tunersports.com/tanabe-revel-touring-sports-damper_mp2344.html
