Aaron T
I'm working on a 2006 civic lx A/T that stalls at idle or runs rough. No DTCs set in the PCM but I discovered that the AC compressor is not shutting off causing the problem. I disconnected the compressor (connector right on top of the alternator) and now the engine doesn't stall anymore. The way I found the compressor wasn't shutting off was that when I was trying to figure out the rough idle I went ahead and revved the engine to about 3000 rpm to see if it would still stall (I was thinking low fuel pressure/volume) but instead it started making a weird sound (it sounded like the car was farting) and spraying something from the engine compartment which I noticed was the pressure relief valve on the AC compressor doing it's job, releasing excess pressure from the AC system. I then tried shutting off the AC with the buttons on the control panel and it showed AC off but I could see the clutch on the compressor had remained engaged. That's when I unplugged the compressor electrically and it disengaged the compressor clutch plus the idle went back to normal. So now I'm going to dig into what's causing the compressor clutch to stay on but just wanted to see if anyone knew of a common issue. The only recent repairs to the AC was an AC cooling fan (passenger side) but that was last year and this problem started yesterday.
