ob1ob
Apologies for the long post but just want to make sure I give all details. While changing the front pads and rotors I found two wheel studs spinning on my right wheel. After cutting off the lug nuts, I used a puller and slide hammer to remove the hub. While installing the new hub, I must have have over torqued the axle nut because the hub didn't turn. I backed off the nut and pulled the hub out a little. I torqued it to 134 ft/lbs. After finishing with this and the pads rotors, there is a scraping sound from the front right wheel while driving. I bent the dust sheild and greatly reduced the noise but didn't completely eliminate it. I'll mess with the brake shield some more. Should I be worried about anything else like wheel bearing damage when I installed the hub or something else with the brakes? Thanks.
