Okay, so i'm not sure about the 03 models, but i have an 04 and its just a VTEC motor, not iVtec... it is a K-series, it just the cam doesn't changes degrees like the SI or RSX, so it's more like a b-series motor. the cams have lobes on them and they open and close the valves at certain times. the cams are attached to the cam gears and with adjustable ones you could change the degrees on them this makes it either more rich or lean at certain rpms so you can adjust the torque curve for either low end or high end... for drag racing it is usually for high end, well your car's engine has a fixed cam gear you can buy an adjustable cam gear for it, but you can only set it while the car is stopped.with the new i-vtec engine, the cam gears adjust automatically whenever you need the power at the low end or top end of revs honda got the idea from racers always using adjustable cam gears on their cars. the i-vtec adjusts it automatically so it's more fuel efficient while providing more power at the same time...all in all Vtec is Vtec, i don't believe there is a "lower" level....oops correction since you and both have D17A2 engines, it's a D-series not K...
