iriddell
ok i just finished my DOHC ZC swap into my 1991 civic hb Si, but i have found that there is a plug with no where to go.
On the original D16A6, it plugged into the back of the intake on a little module that stuck downwards. (see pictures) on the ZC intake, there is no such module. I checked the manual but couldnt find what this plug/module does... its has two prongs and on the module, it would appear there is a vacuum line that attaches to it. The intake manifold on the D16 says "PM-6" and the intake on the ZC says "PM-7", referring to the ECU's, respectively. I cannot find a connector for this plug anywhere on the engine! (Note: this is the 1991 Si wiring harness I'm using.)
So, here is the Si intake...
http://www.flickr.com/photos/60304820@N02/5504293297/in/photostream/
And here is the ZC intake...
http://www.flickr.com/photos/60304820@N02/5504888022/in/photostream/
If you have any suggestions as to what the flip i should be doing/where this plug should go/what it does, I would much appreciate the input!
Thanks!
- Ian
PS - great forum for information!
Thanks!
- Ian
