wheel isn't going to fall off. The part you replaced was the camber adjustor. So like everyone said, to go a reputable shop and ask them to look around for you, or just get an alignment and see if the problem is solved.Yeah thats all the way off the jack and I haven't noticed any thing els bent.. do you think it could be the wheel bearing also. .. I just don't want to drive it and have the wheel fall off.
Sent from my SM-G360T1 using Tapatalk
There is no camber adjustment on the rear. At least with the factory type upper links. Toe is adjustable up by the front of the trailing arm. If he gets an alignment done and camber is way off then that would lead me to believe there's something else bent from the impact.wheel isn't going to fall off. The part you replaced was the camber adjustor. So like everyone said, to go a reputable shop and ask them to look around for you, or just get an alignment and see if the problem is solved.
Drive the car, straight to an alignment shop.Yeah thats all the way off the jack and I haven't noticed any thing els bent.. do you think it could be the wheel bearing also. .. I just don't want to drive it and have the wheel fall off.
