99 civic no start hot
Radicalracer
99 civic d16 automatic. Runs great but after shutting off hot will crank nonstart. Smells like it’s flooded and has new fuel pump. Cool or distributor?? I have read a lot about the main relay but it sounds like pump is running for the normal 3 seconds
91LXDriver
I had same symptoms on my 91 Civic. I replaced the main fuel relay and temp sensor and issue was resolved. Some say if you 're soldered the terminals in the the main fuel relay that will solve the issue, I'm not that good at soldering I replaced mine. You can get both at local auto parts stores or order them from an online business like rockauto.com. both about $50 and an hour work is all it takes.
