!996 EK CX with 99 b16a - Cluster wiring harness question
Pete96cxEK
Hi All,
So I started this project 20 years ago, life happened and the car was stored. It is very close to being finished but it's been a long time since I worked on it.
My question is I have a 96 CX that I put a b16a in, the car runs but the cluster doesn't work fully. Do I need to change the cluster wiring harness for a 99-00 SI one?
Thank you
nd4sped
Moderator
As I recall you should be able to swap the cluster in just fine as long as you had a manual before hand. I cant remember 100% if you need to change a pinout for milage and tach to work. Ill get back to you on this. But in the meantime, def search the forums as I am quite sure its been covered before.
Ill update with another response as soon as I have an answer.
...and welcome to the ClubCivic forums!
nd4sped
Moderator
Check that thread out and let me know. If you are not getting a tach response its probable the cluster is bad. But there are ways to test this :D
Pete96cxEK
Thank you very much for the response, I will do some testing and get back to you.
