AC/Heat Blower not work, ideas?
#1
When I first towed the car home I tested the heat and blower worked fine. All 1 thru 4 turned on and no issues.
I did notice the belt for the AC was missing due to the tension pully missing. So I replaced it and put a new belt on.
Over the past few weeks I have replaced 1/2 the engine, exhaust, intake, and I have cleaned everything....
Now with the car running.... the heat/AC blower does nothing. I have replaced the switch thinking it went bad and still nothing.
I have checked the fuses, etc... and everything seems to be fine. I ran a wire off the black/blue wire to a ground and blower turns on. I have traced wires and cannot find anything loose....
Anyone have any ideas what I can try next?
#2
What car? The blower circuit has two fuses -- in dash and hood fuse boxes.
Check both.
Have you checked the relay?
#3
95 Civic LX
I have checked and replaced both (just for giggles).....
Not the issue. Like I said both wires going to the blower motor are getting power when the car is running....and I was able to ground the black/blue wire to run the blower at high..... if the fuse was blown none of that would work.
#6
Thanks RonJ!
Found the black wire on the back of the switch (ground) was not grounding right. Ran a new wire off it and created a new ground and works great!
Now to wondering if the AC even works........ starting to wonder what I got in to with this car!
VigLink badge
