ac..
kdawg97ex
alright i got a nother question for u all i turn my ac on and its cold when im driving but when its at idle it idles funny and then no more cold air but once i start goin after a second it comess back on does n e one know what this might be?
Jas0n
What's up dogz!!!
I got kind of the same problem here
MasterShake
the ac compressor runns with a pump wich is powered by the engine, when the engine isnt really "reving" it cant reall pump it. you can also try recharging your ac unit
kdawg97ex
yea it was just recharges some one was telling me there is a switch to keep the rpm higher when ac is on could that be broke maybe?
MasterShake
no the motor automatically adjusts when a higher load is pushed on it, aka a/c. you could raise the idle manually tho.
kdawg97ex
so why does it idle hella funny when i put the ac on and then the ac turns off or it stops working till i start to go .and it idles fine??
j_fukin_t
because the a/c compressor is putting a load on the engine (which is pretty bad on my b16) its common and of course your going to have warmer air at idle compared to 3k when its actually got some rpms for the compressor, everything you explained isn't uncommon so don't worry about it, (and your air will be colder on recirculation btw)
BlackHopeDC5
Is Black Again??? :shock:
it pulses right... mine too....
j_fukin_t
kdawg97ex said:
i guess my question is why does the ac not work when im at idle?
then they possibly didnt' charge it right or its not at correct pressure, cause mine sitting at idle isn't as cold as when i'm driving BUT its still decent enough to cool off my car while i let it warm up
kdawg97ex
well at idle mine puleses for a minute then its like the ac disengages for a few minutes then tryes to come back on while im at idle once its disengages my idle is back to normal
