maksick
Hello everyone, there is a Honda civic 6 coupe. Previously, there was a
automatic, the former owner swap on the mechanic, swap badly, leaving the native P2P brains with all the ensuing problems, automatic transmission errors burned, idle speed floated, reverse gear did not work. I did the idle ones, in the break of the black wire with a blue strip, a 10 Ohm 5 watt resistor, I made a reverse gear, but I can’t fix the automatic transmission errors. For the place of solenoids A and B (Solenoid connector, this is a Yellow wire and a Green wire with a Black stripe, I soldered to them according to a resistance of 15 Ohm, 2 Watts, twisted the second ends of the resistances together and threw them to the ground) As a result, we have two errors in automatic transmission, what else missed?)
