Aftermarket steering wheel HELP!(2000)
Aguespinosa
i unfortunately cut out the srs reel off and a harness holding it in place leaving me with one harness and the other wires which belonged to the harness i cut out, which i believe is a positive and negative cable since its just 2 cables (horn perhaps, not sure). i would like to install my horn and turn off the srs light that has been on ever since i installed the steering wheel; however not by just removing the bulb, i know there is a way of confusing the system to believe there is a airbag through a 2.2 Ohm resistor but again i dont know what cables i would have to connect the resistor to. anyone if you could assist me it would be much appreciated, thanks in advance.
if it helps i have a honda civic 4dr ex 2000
CHILD
All Day, All JDM
The resistor goes to the obivous yellow connector for SRS.
Aguespinosa
When disassembling the panels to get to the cables that were left behind I was encountered with 2 cables in which one had a harness which was black and the other I had cut off
