airfuel guages?
CiviKid
Post Whoralicious
wherecan i get a good cheap air/fuel ratio guage and a one pod a pillar guage pod? and do you just wire those guages inline with one of the o2s?
Linguistics
Live Manikins
i got my cf auto meter dual gauge pod from optionsauto.com. $44 shipped 2-day :thumbup:
TurboZinc
You can get an air/fuel gauge just about anywhere. Autometer makes an a/f gauge with a carbon fiber back.
Those gauges are total crap. If you just want a light show then get it, but don't expect it to be too accurate. If you want an accurate reading of your a/f get a pyrometer or even a wideband o2 sensor.
I'm pretty sure that the cheap a/f gauges just wire into the factory o2 sensor(s).
Linguistics
Live Manikins
yep, hes right and right. a/f gauge equals light show unless youre at full throttle, and it just goes right to the o2 sensor. its pretty easy job to do, but i dont think its worth it. im keeping mine for now because i spent money on it and havent quite figured out what i would replace it with
JDM James
Ominous
WHITE IS THE KEY
When you wire the Air/Fuel gauge to the stock O2 sensor it connects to the white wire because there are 4 on the O2. I forget which one it is but if you wire to a certain wire on the O2 the "check engine" light will come on.
JDM James
Ominous
well if its USDM it would be on the front of the motor....
look for 4 wires all together
DragonHeart
The front of the motor... meaning the side that is facing me when I open the hood? is it near the vtec solenoid or somewhere there abouts?
Ominous G2
ClubIntegra.com
Mad Tachs
That place has a ton of gauges, the Lunar has the pyrometer and the af ratio. Don't buy them just cause they are pretty.
