mainejim
The alternator belt on my 02 Civic DX needs to be tightened. Sometimes the squeal is REALLY LOUD! I know it's not the power steering pump 'cause that's easy to tighten and I did and that didn't help. Plus the squeal sometimes happens when I turn on the headlights.
I found a service manual procedure and illustration online that is partly helpful, altho the directions refer to a bolt (E) that is not shown in the illustration.
Today I removed the power steering pump, assuming this would enable me to see the alternator mounting bolts and tightening mechanism. I couldn't see any of that. Even using a small mirror and flashlight, I couldn't get my hand in a position to hold the mirror to see what's going on.
Judging from the illustration I found, I think the tightening mechanism is missing. Maybe the last guy just used a pry bar to tension the belt and then tightened the bolts?
My question is: is there any way to actually see the lower mouunting bolt and tightening mechanism? How can I deal with nuts I can't see?
Any info will be appreciated.
