So me and Mike (the owner of the civic) and I think we're going to try to Vitara pistons setup. Just curious to what rods you guys suggest. Right now we're looking at Eagle. But before we even build the block we're going to hunt down a turbo setup. Whats turbo is recommended to run on the stock block (untouched)? And at what psi are you guys running safely?
this is a D17 right?
if so Eagle rods arent an option and niether are Vitaras.
the only way Eagle rods are an option is if you swap a D16Y8 crankshaft and oil pump in. as well as Eagle rods for the D16Y8.
vitaras on the other hand are a 9.0:1 compression ratio piston for a D16Y8 or whatever your putting them in.
in a D17 they will drop to about 8 flat. as long as your using a D16 parts mentioned above.
i would suggest if your going with Eagle rods. to buy a set of pistons that are of stock replacement to the D16Y8. but make sure they are reliable. dont put real stockers in if your shooting for the 300 whp goal or higher. this will bring your compression up to maybe 9.0:1 but i dont know. you would have to plug some numbers in and do some math.
in all reality you could run Vitaras and get away with it but dont expect any power in the low end. and expect later spool times.
as for the other question. you need to decide on a turbo before you decide on a PSI to run. to make 400 hp a GT35R is prolly what your gonna need. to make it with that turbo prolly 18-22 psi will do the job. the block itself can proly handle 20. but i wouldnt push it too much. id get it sleeved just to be safe.
now...use this info as you wish. i myself have not made it that high yet with my D17. i will. but it will take me a while. i plan on running the same setup i just mentioned.
oh and one more thing. you will need one hell of a management setup to even think about those numbers.. also a custom intake manifold is in order or you could run a Y8 manifold. there is a how to for that but you need to track that down on your own. with the Y8 manifold you will get a better selection for fuel injectors too. words of advice. a tried and failed method here...RC injectors or any other aftermarket injector will not fit the D17 fuel rail. also the D17 is a returnless fuel system. this means you will need to run a return line and an aftermarket FPR. obviously a bigger fuel pump.
keep all this in mind that it wont be cheap. dont leave the small s**t out thinking you dont need it. the stock intake manifold is made of plastic. there are reports that it will blow apart at anything higher than 13PSI. some never made it past 10PSI and it took a s**t. i run 12 and it is still holding up. once again...use this information as you wish. you dont hafve to listen to me since i am not at those numbers. but that is my plan to get there. and i will get there.
