B series swap issue
Chuckbob
I have a 2000 Honda Civic ex I used the stock y8 engine harness
I installed a b18b1 with a skunk 2 intake manifold and stock throttle body.
Car will start and stay running but once I give it gas it stalls.
Any help appreciated
simmons5.0horse
Check the throttle position sensor. I know they'll do that if they're in plugged
simmons5.0horse
I would probe the wires at each end (At the ecu and at the engine) and do a continuity test with a multimeter. To make sure there's not a break in the wires.
Chuckbob
Reset ECU bt removing BackUp fuse for 5 minutes. Then run engine to see if both codes return.[/QUOTE
Reset ECU by removing BackUp fuse for 5 minutes. Then run engine to see if both codes return.
Check whether the IAT and EVAP connectors are swapped. This error often blows a capacitor in the ECU.
Also check whether 7.5A dash fuse 15 is blown.
ok I will check in the morning thank you
Chuckbob
So come to find out the tps and map sensor plugs were swapped so now car will rev up.
No fuse was blown
The only code that scanner reads now is the p1298.
Car seems to be running like normal.
