b16 problem
Bam
#1
alright, i have a b16 in a HB, and theres somehting really wrong, it seems like everytime i shift gears i lose a little power, and its gotten soo bad i can barely beat my freinds stock d16. im just wondering what it could be, my guess is the v-tec is out or the ecu is malfuntioning. but ive never been in a civic without no v-tec so i dont know what it feel like, oh and anyone here ever had to shell out money to fix v-tec?
DLS TekNiQue
#2
thats not your problem...your you may have a leak in your pistons...it happened to my friend and the same thing is happening like you described. check the block for leaks bro...just take it to a mechanic
b18bhybrid
#4
clutch perhaps!
How is your clutch holding up! Slipping clutch will cause you to loose power between shifting... Look at your tach between shifts and listen to your motor - this will tell you if your clutch is slipping.
infinitexsound
#5
yeap
check the clutch dude.. your motor might sound all good and tasty.. but ur clutch is slippin.. get a stock clutch. from a auto parts store is fairly around 140. trust me on this i just changed my clutch and it feels way better then before....just raced a fuckin firehawk but lost though... just because my car is still kinda stock... turbo is coming along soon.. that would beat that daymn firechicken....
99CX
#6
Check your oil pressure if you dont think VTEC is workin, low oil pressure will cause your ECU to stop engaging VTEC. Sounds like a clutch problem to me though.
ReVtecSi
#7
if you arent hitting vtec then you might be low on oil......when youre low vtec doesnt engauge.....another power loss might be a slipping timing belt or a slipping clutch....get all of these checked out.
Sammo115
It be me, Sammo
#8
Check your linkage from the vtec solenoid or the fuel pressure link...This kind of problems happens to every one...
