Bad Rocker arms?
kuqog
Whats up guys. I have a 96 spec GSR swap only has exhaust and CAI and its been making a loud ticking noise coming from the head its more noticable when im driving not so much at idle . Thought the valves needed adjusted went through and checked and they were all within spec did i compression check and that checked out too. So I'm now thinking rocker arm but I dont want to just throw parts at it so is there a way you can diagnose a bad rocker arm? Any help is greatly appreciated
nd4sped
Yes you can measure the rocker arms to ensure they are within service limits. If they are not, start replacing the necessary components.
Can you post a video of the noise so we can get a better understanding of exactly what you are hearing.
Your initial analysis was spot on for valve adjustment as this is typical for Hondas to be inspected and adjust every 50-60k miles or so. I personally do it every 5k on the racecar and 15-20k on the dailys.
