Dingo777
i have a built d16y8 and my # 1 question is timing. i put my motor in my 91 civic and iam using the 0do1 p28 .the d16 factory timing is 12 + or - 2 . so if i send my p28 to put a base map in the base map timing should match the ignition timing correct or wrong.and if i advanced my dizzy to 10 or up to 14 then do i need to go back and change it in my base map. #2 question is if i advanced my adj cam gear do i need to go back to the dizzy and reset timing? =
