Can't go in any gear when cold
jeders
Guamster : ]
Just replaced the clutch master, clutch line, and clutch slave.
When the engine is cold, it takes at least 10-20mins to finally get into gear. ANY gear, when it finally does its still a b***h shifting cuz its real rough. After driving 20+ mins, the shifting and everything is normal.
My clutch, bearings, pressure plate, etc are all new as well.
I'm also trying synchromesh / honda MTF right now. hope that fixes the problem. If not, anyone have suggestions?
Gunner
Did you bleed it after you replaced the slave? you may have air in it
JohnS.
BANGARANG
I was going to say if it's a cable tranmission you may want to check your cable but judging by your avatar, I'm assuming you have a hydraulic transmission? Did you bleed the system and get ALL of the air out? Is the MC adjusted properly?
gugiey
what are your rpms at when its idling
I have just noticed this on my civic but i can like force it in gear and it goes .
JCCLARK
The Painter
Bleeding on a Civic is usually the problem.
Most Civics have a clutch line that goes uphill on
the firewall and if you only bleed it a little the air bubble will just travel
back to there when you stop.
You have to bleed it a lot to get all the air out.:cool:
jeders
Guamster : ]
sorry, its an obd-1 B16A. yea, it was bled good. it was working fine after we changed it. just recently this started happening. i'll try bleeding again and let y'all know. thanks!
jeders
Guamster : ]
damn, i tried bleeding the clutch again with a friend. now it can't go in any gear even when the car is warmed up. ugh, gotta take it to my shop again. i hope its just a bearing problem or nothing too serious.
jeders
Guamster : ]
friends and myself had finally dropped my trans. half of the pressure plate bolts were loose! idk how or why lol but its all good now. dayum!
