foodlegs
Hi guys. I have a manual transmission 1996 Honda Civic CX hatchback. A few days ago I let my friend borrow it for a ~40 mile drive. The car had been running well prior to this and for most of the drive my friend experienced no problems and spent most of his time cruising in overdrive on the interstate. Suddenly, the check engine light started flashing and my friend ran into a red light before he could pull off the highway. When he tries to launch the car in first gear from idle at the stop light, the car suddenly barely has any power. He manages to get off the road, and the car no longer has any power as this point - flooring the throttle in first gear causes the car to creep forward several inches very slowly. At this point, the CEL is now solid instead of flashing.
Now that I have the car back at my house, I've been looking at it myself. I scanned the ECU while the CEL was on and it returned cylinder misfire codes for 3 out of 4 of my cylinders (P0301, P0303, P0303) as well as P1300. However, the engine sounds pretty much fine at idle and revving only sounds a little bit choppy (which it didn't before). But the car still absolutely won't move. My gear selector feels fine. I would normally assume my clutch is bad, but too many things here are throwing me off. The CEL cleared itself and now it won't come back on. The fact that the car simply stopped receiving any kind of power from the transmission doesn't seem like a clutch issue, and I've adjusted the clutch placement rod behind the clutch pedal and nothing has changed. I'm going to replace the clutch fluid tonight as a formality.
TL;DR: Car won't move at all. CEL says engine misfire sometimes, but engine sounds normal.
Has anybody ever heard of anything like this? I'm really confused, it seems like this could be anything from an engine problem to an exhaust problem to a clutch/transmission problem. I really want to eliminate other possibilities before I need to replace the clutch or even drop the transmission.
Sent from my SAMSUNG-SM-G891A using Tapatalk
