Cleaned IACV, car idling dangerously low.
young_
out on bail
#1
I've been having problems with my idle lately (idling too low) so I cleaned my IACV just like all the write-ups say and now it's idling dangerously low, feels like it's going to stall. But I put both wiring connectors back in place, both lines at the bottom are back on securely, not sure as to why I'm having this dangerously low idle. Any ideas?
Edit: Maybe I should try and reset my ECU?
young_
out on bail
#3
Just reset my ECU following these steps.
1. drive car til its warmed up.
2. turn car off, disconnect battery or pull FI ECU fuse out.
3. put fuse back, start car, close hood
4. make sure all accessories are off, do not press any gas or brake
5. just let the car idle for 10 mins by itself
6. turn car off, then back on, and go for a drive like you normally do. it will take usually one tank of gas to completely relearn the fuel trims.
Still nothing. Any other ideas?
young_
out on bail
#4
Bump.
Need to get this fixed ASAP. Any ideas at all?
young_
out on bail
#6
I had a similar prob, idk if d series have pcv systems but check that if you do and make sure it isn't clogged or anything
Make sure all hoses are hooked up right and not clogged
I am here: http://maps.google.com/maps?ll=34.877212,-99.509423
That makes sense but I'm pretty sure my solution has to be in what I've messed with. I haven't changed anything other than cleaning the IACV. I'll look into it though
young_
out on bail
#9
Bump, any and all help is appreciated, Any way my IACV could be bad? All I did was clean it, and my problem got worse,
young_
out on bail
#11
On the way home from work tonight the car did fine. Idled around 500 rpm. maybe 600. Could it be the O2 Sensor taking too long to respond like you mentioned previously?
ImportFan1
Super Moderator
#12
Are the idle speeds different when the car runs cold vs. when it is hot?
00siboy
lurkin...
#17
If I could threadjack for a second...maybe it could help.
I have a similar problem with my em1. It idles at around 1500-1700 cold, and as it slowly warms up, the idle slowly goes down, until at FOT it idles at around 600. I just replaced my iacv today and there is no change. So the problem doesn't sound like your iacv, maybe I have an o2 issue as well...?
antie22
i
#18
im exactly where you are at man...its driving me nuts.
