Climate Control / Fog lights dead
SpeedBuggy
So today it rained all day, and I decided to tinker a little with my fog switch and i came up with this
it worked fine when i turned the fogs on then about an hour later, my climate control wouldnt start up, it lit up but thats it, any clue what happened??
EDIT- and my fogs wont work now either
eskateboarding7
the climate control wont light up, or will not function at all?
eskateboarding7
Check the under hood fuse box...there should be one for the blower motor. That could be one problem. If not, look up a fuse diagram for the underdash fuses....
SpeedBuggy
thats was i was thinking..a blown fuse somewhere, but i dunno about the fogs, plus something made a spark when i was tinkering inside the double din part, maybe that shorted something?
eskateboarding7
definitely check fuses. Do you have any bare wires back there? Like from a headunit or something? Those leads could definitely cause spark and blow stuff.
SpeedBuggy
so i checked my fog fuse and relay, everythings ok there, so i dunno why they wont work =/
knightxrider1
i would check the grounds to the fog lights. mess around w that makin sure it has GREAT contact. and the relay. does it click? even so, manually squeeze the contacts together, sometimes the coil lost its strenght
SpeedBuggy
well i put a brand new relay in or my fogs, and no, it does nothing they still dont turn on, and i checked my ground and its all good too. its a mysteryyy
knightxrider1
dont you have a voltmeter? thats an important tool. it fixes every electrical issue.
Black Magic
I'm Rick James, b***h
^ x2
it definitely sounds like you shorted something. Check all of your fuses. I blew the fuse for my tail lights and for some reason my foglights stopped working even though they're wired to the parking lights. But after I replaced the fuse, all was working well.
As for the blower, did you try turning it up all the way? Mine stopped working when I switch it to 1 or 2 but 3 and 4 work fine. I still haven't figured it out, though.
zammykoo
caffeinated
yep its definately a blown fuse, check the ac and fog fuses
i know when i was tinkering with my alarm i saw a spark and then i checked the fuse under the hood.... sure enough that was the problem
