Clutch upgrade
Mar
Good day ya’ll.. trying to revive my 96 ex coupe and replaced short block. Since the trany and engine separated, I replaced my clutch as well. With the clutch pedal adjusted and able to shift gears, the problem I’m having is the engine wants to shut off when I press the clutch. Appreciate the help.
Mar
Did you upgrade the clutch or just install a new OEM clutch?
Clean the IACV and adjust the idle speed.
Any CEL codes? Does the engine do fine while driving?
Exedy stage 1 clutch kit and no codes. The engine is fine once in motion. I also noticed that the pedal has no play and had to press clutch all the way down to bite (doing it slowly does not stall). When stopping, had to put in neutral early otherwise engine will stall if done near stopping.
Mar
Forgot to say thx
