dyno disaster..help!
myinca
my friend has a '00 civic ex. he dyno'd his car with it stock...then went back to dyno after a few bolt-ons....he put an AEM V2 intake, AEM Pullies, Greddy header, and Greddy Catback....well there was a problem with the latest dyno...and this is where i need help. Im not to familiar with all the Air/fuel stuff but the guy said he was running rich...A/f was 12.1 when should be 13.1.....he said it was fine at part throttle tho 14.7.....what is the ideal A/F at WOT? and what is causing this problem...how to fix it? he did nothing but those bolt ons. thanks for the help. here's the dyno sheets...
STOCK RUN
AFTER BOLT-ONS
a lil treat....623whp stang on the dyno before us
MasterShake
try a fuel pressure regulator. and i heard some where that adding those things make it run rich, not too sure bout that tho.
myinca
we asked but they said that that would not work( he has one in his trunk but they explained y it wouldnt work didnt understand to much of it tho) but is this a common result? shouldnt this not be happening with just basic boltons?
JL
Doodoo Brown Member
You need to run some type of engine management like Hondata, AEM, etc to tune the fuel map. I don't know why such a thing would happen but I'd run it on the dyno a couple more times to be sure.
myinca
yeah thats what we were thinking, hes goin with hondata...but we were just curious bc boltons shouldnt be doin it....it ran the same 3 times on the dyno
nightryder99
hondata is a good system but too expensive for the actual use ...unless he's going to turbo i see no point in throwing money like that
on this site....you can find info on a stock ECU ( the 92-95 civic hatch Si) which can be modified to be reprogrammable..this is something I'm looking into for myself aswell because I just got a intake manifold ...and I'm running to bloody rich myself ( d16y8 )
look into the P28 ....it will cost you half the money ..for almost ( if not the same ) result for this app.
oc_civic
actually because hes only running rich at some rpms a vafc (correctly tuned) would be ideal.. as you can make adjustments per 500 rpm range.. the reason a fuel preasure regulator will not work is it makes ONE solid adjustment.. so say you turn down preasure a bit to lean out the rich areas.. you are now having less fuel preasure across the board thus running lean where you used to run stoichiometric.. a vafc would actually probably be a good fix if he was looking to run perfectly across the entire rpm range..
myinca
arite thanks guys i will relay the info.....what exactly is a vafc..who sells them and how much we lookin at? thanks
05
Show Me Them Titties
is the car being dyno'd an auto?
rei
jSolo
apexi makes it.. it can be found all over the net..
nightryder99
yea but wouldn't the P28 be the better choice??
a VAFC runs for 300 bucks...a modified ECU 100$... + harness 75$ + tune 100$
it would cost you the same price ..tax included than a full modified ecu which will be capable of precise maping of torque/fuel /air/hp maps.... giveing a more precise result
atleast that's how I see it
myinca
ok i see...no the car is not auto...and the hondata he was looking at said 200-300 and he seemed like he wanted to go with that...ill let yall know if we ever find out what the cause of the problem was
