Engine no crank, no start after removing aftermarket alarm system
Divesh Soma
Hey guys, I'm having a problem with my 97 Honda Civic/Ballade 150i. I recently removed the aftermarket alarm system as it was giving problems but , the two plugs that I disconnected the alarm system from is now hanging loose with nowhere to connect and I have also identified a relay connected directly to the starter motor. The lights on the cluster switch on as usual but nothing happens when I turn the key to the start position. How should I go about bypassing the connections?
30870
The two blue wires are where I disconnected the alarm system from
30871
And this is the relay connected directly to the starter.
