Exterior Bulb Size Info
JohnS.
BANGARANG
This is just some very general information regarding exterior bulbs that I would like to condense all into 1 area for 4th-8th generation Civic's. Rather than having to search generation to generation or year to year, it's all here.
I'm not sure if this should be stickied or not so I will sticky for now. Once our technical database increases, obviously we can't have dozens of stickies, in which case this can be unstickied and moved elsewhere if necessary.
Feel free to correct me if any information is wrong! =)
4th Generation:
Headlight low beam bulb: 9006/HB4
Headlight high beam bulb: 9005/HB3
Foglight bulb: ???
Parking Light Bulb Size: 1157
Front Turn Signal Light Bulb Size: 1156
Rear Turn Signal Light Bulb Size: 1156
Tail Light Bulb Size: 2057
Stop Light Bulb Size: 2057
High Mount Stop Light Bulb Size: 921 This may be incorrect. Someone please double check.
License Plate Light Bulb Size: 168
Back Up Light Bulb Size: 1156
Front Side Marker Light Bulb Size: 168
Rear Side Marker Light Bulb Size: 168
5th generation:
Headlight bulb: H4/9003/HB2
Foglight bulb: H3
Parking Light Bulb Size: 3496
Front Turn Signal Light Bulb Size: 3496
High Mount Stop Light Bulb Size: 3497 or 921 This may be incorrect. Someone please double check.
Front Side Marker Light Bulb Size: 3496
6th generation:
Foglight bulb: H3
Parking Light Bulb Size: 1157A
Front Turn Signal Light Bulb Size: 1157A
Rear Turn Signal Light Bulb Size: 1157A
Tail Light Bulb Size: 7443
Stop Light Bulb Size: 7443
High Mount Stop Light Bulb Size: 7440
Back Up Light Bulb Size: 7440
Front Side Marker Light Bulb Size: 1157A
7th generation:
Foglight bulb: H11
Parking Light Bulb Size: 168 or 7443
Front Turn Signal Light Bulb Size: 7443
Rear Turn Signal Light Bulb Size: 3156
Back Up Light Bulb Size: 921
Front Side Marker Light Bulb Size: 7443
Rear Side Marker Light Bulb Size: 194
8th generation:
Foglight bulb: H11
Parking Light Bulb Size: 3457LL
Front Turn Signal Light Bulb Size: 3457LL
Rear Turn Signal Light Bulb Size: 992 (7440A)
Rear Sidemarker Light Bulb Size: 168
JohnS.
BANGARANG
Fixed an incorrect size. The high mount stop light for 6th gen is 7440, not 921. If anyone with a 4th gen and 5th gen can check their high mount stop light bulb for me, let me know which one it really is. Evidently Sylvania's bulb replacement guide is not accurate.
