FAQ : How to change a Intake Manifold
JDMLyfeStyle
DSM DESTROYER!!!!!
How To Install A Intake Manifold
Yes i know its very common and easy to install one but Not everyone knows what is involved in it.
Tools Needed
Socket set- 10mm 12mm 17mm
Wrench- 10mm 12mm 17mm
Drain Pan
Needle Nose Pliars
FlatHead ScrewDriver
Parts Where Purchased From AN-R.com
Blox Intake Manifold - AN-R Link
AN-R Intake Manifold Gasket - AN-R Intake Manifold Gasket
I bought Some Teflon washers as well
Step 1
Pop the Hood and look at the Ugly Stock intake Manifold
Step 2
Remove the Clamps Holding on your Intake a Flat head should do this no problem and remove the Hose going from the intake to the Valve Cover
Step 3
Remove the MAP sensor
Step 4
Remove the TPS wire
Step 5
Locate the IACV its on the backside of the intake manifold. Its the black cylinder.. Now Remove the 2 Coolant Hoses coming off of it. Now Coolant may leak from the hoses so have a pan ready. while your there unplug the the IACV sensor.
Step 6
Now Take a 10mm and remove the Throttle Cable bracket. And Take out the Pin holding the throttle cable to the Throttle Rotor
Step 7
Now Remove the Vaccum line coming from the brake booster
Step 8
Remove the Vaccum line coming from the Charcoal Canister.. I do not have this so no picture of it being removed. Since i Removed the Charcoal canister.
Step 9
Right by the Distributor on the Intake Manifold there are coolant lines. Now Remove them with your Needle Nose Pliars. Now Coolant will leak From here as well. So be sure to have a Pan ready to catch it
Step 10
Grab a 17 mm and Remove the Fuel line from the Fuel Filter some fuel may come out so be ready with a shop towel
Step 11
Go to the Fuel Pressure Regulator and Remove the Fuel Return hose.. Some May leak out so be prepared
Step 12
Take a Razor Blade, Flat head screw Driver or a thin pointy object and remove the Injector Clips
Step 13
Take Your 12mm wrench and remove the 10 bolts holding on the Intake manifold
Step 14
Remove the 5 Bolts Holding to the Intake Manifold to the Rear Motor mount. I do not have this so there is no pictures
Step 15
Remove the Intake Manifold.
Step 16.
Now its time to swap parts over from the old intake to the new one. I started by removing the 4 12mm Nuts from the Throttle Body. Be Careful not to Rip the Gasket. Cause No parts stores or the 2 honda dealerships in my area had these in stock. Also i soaked the inside of the TB with seafoam to remove carbon build up
Step 17
Take a 12mm wrench or socket and remove the IACV off of the old intake Manifold.. Notice this is how i Get rid of that Annoying Fluctuating Idle
Now Install everything in the reverse Order And Have Fun =)
This Has Been A JDMLyfeStyle Write up. Do not Copy my Images to other websites without my permission!!!!!
JL
Doodoo Brown Member
You do awesome DIY's and I save your page in my fav's, much props, but why didn't you just link your page instead of wasting all that bandwith???
