Fog Light Fuse
bkjj77
Were is the fog light fuse located...
I just put new bulbs in and they blew out...
im pretty sure it is the fuse ....i just dont know were it is at
DeathLens
EM1 Crew
it's none of those.
the fuse case should be attached to the harness
bkjj77
so there is no fuse that goes with the fog....cant figure out why they wont work...the fog light switch lights up but the lights wont go on
reptlcal
Caillou
You run an inline fuse for aftermarket fogs. I believe mine is a 10a fuse and is located about 6-7inches from the positive battery terminal. This is the wire that goes from the battery to the switch.
bkjj77
ok i found that fuse and it was blown....i replaced it and one of the fogs went on and the the didnt...
after 5 seconds the other one went out....it blew the fuse again and so i replaced it...this time i removed the l=fog that didnt go on
and now the other one works fine... i took apart the broken fog and the black tape from the H3 bulb wire was all melted....what could be wrong with this fog....did the ground come loose? why is the wire melting the tape? any help please
Broken fog v v v v
dillon_1213
I have the same problem]
mine melted the wire i used bailing wire to see if was just a crappy fuse nope it was the wire in the light so i replaced it and it still wont work the bulb is fine
