1. Mint EX seats from my 00 coupe. (front and rears). No rips ,tears or cig burns. $120
2. Y8 Tranny Slave Cylinder/line. $20
3. Y8 Speed Sensor(works on b-sereies also) -$50
4. Reverse Light switch- $40
5. Y8 Tranny Housing - $75
6. Y8 Motor mounts( rear mount rubber, rear T bracket) $15 each
7. Neuspeed Sport springs. (1.75f, 1.5r drops) -$ 80
8 Mint 00 Si passenger headlight.1 broken top tab, the little tab on the front is broken too. Lense is so mint. - $40
9. Got tranny parts for a 96-00 Y8 tranny(gears, synchros, any tranny part). PM me for these.
10. Complete Y8 swap.(motor,trans, ECU, harness, axles, mounts, shift linkage).New OEM belts/seals. Legit w/ title copy. $550 or $600 with zex stage 1 cam.
11. My EK9 CTR JDM steering Wheel. Momo with red stitching. comes with airbag. $ 350. I no longer need a wheel, found a stock wheel for cheap.
12. (2) OEM Si wings. One blk, one taffeta white. $100 each. (blk wing pending)
13. 00 EX Climate control. -$40
14. 96-98 civic hood. needs to be primered and final sanded. kid i bought it from said it was a 99-00.- $ 60 bucks.
15. 99-00 Civic Fenders. One side is mint, one side was body fillered and sanded at the arc behind the headlight. 90 bucks fer both.(pending)
16. 99-00 civicfront bumper. Just needs to be cleaned and painted. the two top radiator support and side mount points have tears, not broken!!. $ 75.
plastic glue will make em perfect again.(pending)
17.99-00 civic Headlights. (8/10). one broken tab on driver side. Passenger side ok. $75
PM me if you'd like to get ahold of me.
