I've finally decided that i just will never finish this project the way i want, i really want to invest more money and time into a new daily and my 240. The only way ill really be able to afford to buy a new dail is to part out the hatch and coupe then use that money to buy a new daily... SO here is the part out of the hatch , ill have one for my coupe shortly
I have a ton of parts on and for this car so this thread will be changing so check it often.
*ALSO I WILL SHIP AND CAN MEET 1/2 WAY FOR LARGER ITEMS SO JUST PM ME AND WE CAN WORK SOMETHING OUT*
Let's start with the motor: (motor and tranny still in car but can be pulled asap)
*ATTENTION----- I WILL PART OUT THE MOTOR ... IF YOU WANT SOMETHING MAKE A OFFER, ALSO MOTOR HAS ZERO MILES IT HAS NEVER BEEN RAN OR HAD FLUIDS IN IT SINCE REBUILD *
Block: $700 OBO
Y8 block (fresh hone,decked,repainted) (block and girdle have been notched for rods)
Vitara pistons (stock bore 75mm)
Hasting rings
Tuner Toyz rods with arp rod bolts
Acl bearings (standard)
Rebuilt y8 pump
Stock untapped y8 pan (comes with new oil pan gasket)
newer water pump
newer timing belt
Head: $450.00 OBO
Y8 head fully rebuilt (ported,polished,upgraded valves and dbl valve springs newer valve guides ) $125.00
Zex cam 105300 cam $200.00
Skunk 2 cam gear (gunmetal with red center) $85.00
ARP Head studs $75.00
OEM y8 gasket
*ATTENTION--- HEAD HAS A SMALL ISSUE ... two of the two bolt holes are stripped .. one is broke and one can be retapped.. i simply hondabond my vc on and it never leaks *
Intake: $175 OBO
Y8 intake manifold (ported and tapped for NOS shark nozzles) (comes with ALL sensors to work on a obd1 motor) $ 100.00
H22 TB (IM portmatched to TB) $35.00
450cc Blue top injectors (cleaned and flow matched with new O-rings) $SOLD to Phate
Mr Gasket G-Sport Fuel Rail (red) $65.00
Transmission n clutch :
Z6 ex big bearing tranny (no grinds) $ sold
Act 6 puck with HEAVY duty pressure plate (currently installed will be better pictures when removed)
-clutch has usage on it but is good for about another 10-20k of hard usage $75.00
Turbo setup: $sold
Block: $700 OBO
Hasting rings
Rebuilt y8 pump
newer water pump
newer timing belt
Head: $450.00 OBO
OEM y8 gasket
Intake: $175 OBO
Turbo setup: $sold
