headlight cleaning ?
Danno
I've used the 3M polishing compund and got the yellowish crap off the outside of my headlights. How do I get the small rock chips out of the plastic?
Will 2000 grit wetsanding work?
Trey99EK
You could try, but I don't think 2000 will do much. Unless there are really small rock chips.
Partizan
im gay n proud luv my car
danno, fpr ridding of the yellow stuff, you only used compound? How did it come out?
Danno
worked great. I took a bit of time. I let the compound dry for about 10 minutes and then rubbed it off. They cam out great and made a big difference in the look of the headlights.
Danno
Partizan said:
so no sanding at all?
No sanding. I'm wondering if the small nicks and chips would go away with sanding? But trekk99ek is probably right, 2000 grit is vet fine. I had a friend who did it with 1000 and lots of water and he scratched his very badly.
Danno
Partizan said:
do you have any pics ?
no...sorry. All I can say is it looked like I had dry pee on my lights and now they are clear. ;)
Jas0n
What's up dogz!!!
wich kind of headlights do you have? will the 3M compound work on sonar headlights? because mines start to get too yellow.....
Danno
Mine are stock but the compound works on any headlights with outer plastic housing.
Jas0n
What's up dogz!!!
I'm gonna try that, any tips for the process?
gearbox
meguiars plastX works pretty good too but for rock chips theres nothing that can really fill those holes.
AutoFanatik
gonna try this either tonight or this weekend, did you take the lights off the car?
Danno
No, but I did put painters tape around the lights to cover the paint.
gearbox
i applied 10x coats of plastx with hard rubbing and it got better, but i still have alot of scratch. lousy ebay. should i just finish the bottle and maybe it will keep getting better?
AutoFanatik
mine's not too bad...i just want to nip it in the ass before it starts growing/expanding you know?
gearbox
i guess ill go spend some more time lol. anyone know if scratchx is safe/okay to use without hurting it? worked great on clearcoat scratch.
PEPE LE PU
mods yea i got some
another way is to wet sand 2000 then 2500 then 3000 then polish out the fine scratches it will turn out like perfect i have done several with excellent results or if you dont want to sand if you have a high speed buffer and a wool pad along with some heavy compound you might get some out but not all hope this helps
gearbox
i might try the sand paper. its just there are so many all over and its starting to look cloudy when the lights are on. it looks fine in the sun obviously.
