Ryley92
Hello,
Working on a 99 civic dx 1.6
It's throwing knock sensor no signal codes P0325 & P0330
I first replaced the sensor. No change
Then I ran a cheater wire from the 1 pin on the sensor directly to the corresponding KS pin on the passenger footwell engine ECU connector C ( I believe it's a red/blue wire, might be remembering that incorrectly but it's definitely connected to the KS pin)
No change.
Still getting the same codes which set immediately after reset
I have reset ecu and cleared codes etc.
Then I took a closer look at the wiring harness near the knock sensor (under the intake manifold)
I discovered 1 wire which is yellow/red and it's just dangling there right near the knock sensor
Anyone know what this yellow/red wire I'd or if it's related to the knock sensor codes?
No change.
