The Problem:
I got an EG9 civic with a stock B16A engine, and I have a problem where the engien will work fine when cold. However it will start stuttering on acceleration when the engine gets to driving temperature (usually after 20mins of driving). And the CEL will light up when I keep the revs constant for about a minute, error of the code was 43 which is the O2 sensor.
What has been done:
- the usualy parts of the car have been services/replace (oil & fuel filter, new spark plugs, new leads...)
- Replaced O2 sensor.
- replaced (and removed Catalytic converter) exhaust piping from manifold to the back box.
Note:
Another problem I have and not sure if its linked ........... As you know the civic has dim, driving and high lights and mine work normally when the engine is off. However when on and the switch is placed in the dim light position, the driving lights go on too however not at full lumincy.
What has been done:
Note:
