Honda Accord Idle Issue
Micsm08
I know this isn’t a Honda Civic, but I have a 2002 Honda Accord that drops rpms when it starts. When cranking the car it seems fine until a few seconds passes, then rpms drop super low and the motor begins to shake. I’ve noticed that when I crank it and give it some gas that it will stay running until I let off. Then it begins to drop and shake again.
Mr.Baker
Mr. Search
Check this thread about cleaning the IACV & stuff.
https://honda-tech.com/zerothread?id=1844067
In that thread, it describes how to set your BASE idle (which is not the same as the operating idle). Then reset your ECU and let it re-learn the behavior of the idle system.
Also check the idle screws.
decocamber
I have a 2001 Honda Accord Sedan which is unable to idle at a constant RPM. It will hold the idle RPM until it warms up for a minute, or until you touch the throttle. Then, it starts jumping from ~2k to 3k RPM. I've tried resetting the idle control, and I've read that cleaning out the idle control valve may help, though I am having trouble locating this. When I wiggle the electrical connection that looks like it's connected to the idle control valve, the idle jumping stops, until I plug it back in. Recently, my obd2 scanner gives me the code "P0108: Manifold Absolute snaptube vidmate Pressure / Barometric Pressure Sensor Circuit High".
