Hey everyone!
We thought it would be nice to post up a quick guide on how to wire up a Mishimoto Electric fan. I'll start by saying that we posted this How to Guide up in order to answer any questions. We do make performance parts for vehicles which come stock with belt driven fans, and this is basically how they would wire the fans up. I have also seen a few Hondas/Subarus/Acuras/etc that have the fans wired up like this in order to continually have the fan going.
We hope this is helpful and can answer any questions you might have!
MATERIALS NEEDED:
- 1 x 5 post relay
- 2 x 10 AMP fuses
- 15 feet of 18 gauge wire
Instructions:
Run a 12 volt positive wire to the relay (put a 10amp fuse in this wire). The other side of this relay is the positive connection to the fan.
The ground from your fan can be grounded to the body of the car. Make sure it’s a good ground.
Find an accessory wire to tap off of. This is a wire that becomes hot when the key is in the “on” position.
Tap a wire off of the found accessory and run it to the switching side of the relay (put a 10amp fuse in this wire), and then ground the other side
of the switch.
Wiring your fans like this will make them turn on when the key is in the “on” position (when the engine is running).
Please refer to the wiring diagram below.
MATERIALS NEEDED:
- 1 x 5 post relay
- 2 x 10 AMP fuses
Instructions:
of the switch.
