how to install fogs on a 98 civic
sean360
#4
well i dont have any yet ill probabbly get aftermarket im waiting to get them unill i find out how to intall them,,,,,are stock ones better?
Jay Jay
Administrator
Premium
#5
I have stock ones in my 97 civic and I hooked them up to run off my parking brakes instead of the switch. since i forgot to turn them off a couple of times and killed my battery :oops:
knockoff
you can call me ABE
#6
do you have pics of the stockfogs on your civic
justin???? id like to see what they look
like :thumbs up:
knockoff
you can call me ABE
#8
Originally posted by "admin"
I don't have the stock ones, they are cheap aftermarket ones.
oh, my bad :oops: i thoughtit said you had stock fogs in the previous post??
sean360
#9
well i just need some pics of what wire to splice the fog lamps to cause i dont know what wire is what :?
GOOSE
JDM yo!
#13
is there anyways u can put like a noice so when u open ur door and ur car is off.. so like u know when u turn off ur car and it just BEeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeps... till u turn ur lights off is there anyway to do that with the 96-98 fogs???
TorGa3iGhT
"torga eight"
#16
as far as wiring goes, you can go to autozone, and buy one of those fuse splitters. It basically goes into where a current fuse is in the fuse box, and also contains a positive lead coming from the fuse. From there you can wire your positive wire, down to the switch, then to the fog lights. The ground just ground to anywhere on the car that is touching the metal frame.
I haven't actually done fog lights on my car yet, but the wiring should be the same as anything else. Just make sure red goes with red, and black gets grounded. Lemme know if you need more help...i can try and give you a more detailed idea?
XcLuSiVeLy4GoD
ODP
#17
bringing this one back so as not to start a new one about the same thing, but has anyone come up with a diy aftermarket foglight install? i found some rectangle, yellow foglights that im lovin and i want to know how hard it is to install, and how to do it. i want to use the switch because where i want to put it is right above the e-brake where theres thsoe lil rectangles.... one of mine is gone so i figured why not cover it with a switch.... tha actually works!!! lol. but yeah help me out here please!!!
98EK-R
"Keeping It Clean"
#20
So i have a 98 w/ the 99 front end, which set of directions do i use, 96-98 or the 99-00?
VigLink badge
