how to install an intake
worked for me but if you mess up not my fault
ok first you need the following
1) car 2) intake 3) tools the tools you will need "or that i used" are the following. One flat head screw driver a 10mm soccet and a 5/16 ths socket" i think thats eater 6 or 7 mms".
1- ok first take of fyour stock intake box assmbly. it has 3 bolts on one of the boxes and 2 on the other." the second box right on tom of the trottle body i just yanked and moved it untill it came off " this douse not hurt it unless you forget to take off the o2 senser.
2-take off your front bummper there are little plastic circles you just pop them up with your flat head and then take them out there ia about 8 of these on the top part of the bummper. then go infront of the tires their is a smal bolr right behind and under the headlights. unbolt this "both sides" and take off the bummper". styraphome is inder the bummper too so dont break that.
1put together your intake losely at first then you have room to move it so you can have it just right
look for the pic-this is the bottom half i dident connect it to the top half because i stcuk it through the hole and then attached the filter here ----
heres another view all put together
and last i cut a hole in the little plastic fake airscoups so i could get direct air flow when driving i also used a file to make the edges look nicer
tell me if this helps any one out or if you have any questions enjoy
