How To: K-series engines into the EK (1996-2000) Civic's chassis
NOFX
I'm NOT eran!
Hybrid How-To - K-series engines into the EK (1996-2000) Civic's chassis
This is an article I found in the July 2004 issue of Sport Compact Car. (If you don't like the magazine, keep it out of this thread. This thread is not meant for battles on which magazines suck or not.) This article refers to the cover car, a Roma Red 1996 Civic hatch with a K20 swap in it. There is also a corresponding article on the car called, The RedDevil.
Hybrid How-To
BY JARED HOLSTEIN
PHOTOGRAPHY BY: TIM KELLY KEVIN WING
Hybrid No. 15:
WHAT AND WHY
Face it, the D-series in you Civic is far from anything special. It's a fuel economy engine. If you want more power, it's forced induction or a swap. Installing a B-series swap is easy, but Honda hasn't made a B-series since model year 2001. Supply is shrinking and they're getting pricey.
The future of Honda engines is the new K-series, under the hood of the Accord, Element, CR-V, TSX, and RSX. Figure more than 400,000 of them are sold each year. They're already in junkyards and the minimum power is 160. Plus, the 2.0-liter version has lots more torque than a B-series swap and the 2.4 even more still.
The EK Civic is the last generation with a double wishbone front suspension instead of cheap MacPherson struts like the 2001-and-up models, and the handling potential of the EK models are well beyond that of the newer cars. It's also lighter and has lots of non-engine-related performance parts and bling-bling parts available.
Code:
[U][B]
[SIZE=3]Swap Basics[/SIZE]
CHASSIS: 1996-TO-2000 HONDA CIVIC, SIXTH GENERATION, ALL MODELS			[/B][/U]
They all came with D-series engines (except the Si) so they all have the same
mount locations. The fastest units, post-swap, are the lightest, which are
hatchbacks. The CX has a factory-listed weight of just 2,250 pounds. But even if
[U]you have a plump EX sedan, this swap works.
[B]ENGINE: K20 OR K24[/B]								[/u]
The Hasport kits work with either size engineand with all the combinations
like a K24 from and Accord on the bottom end with a K20A2 head from an RSX
Type-S. The K24 motors have EGR built into the head (except the CR-V), and the
K24A2 from the TSX has a different ECU and harness. Other than those anomalies,
[u]they're all the same electronically and emissions-wise.
[B]CONCERNS[/B]									[/u]
If you've done a Honda hybrid swap, this is no tougher. Three mount points,
three new custom mounts. You need a custom exhaust and driveshafts, but Hasport
is currently supplying the necessary parts. The wiring is very tricky, however.
Plan four to five hours on wires alone if you go it yourself, or just buy the
[u]Hasport sub-harnesses.
										[/u]
Emissions may require a lot of work, depending on your state's rules. The 1999-
to-2000 cars generally have all the sensors the K ECU is looking for, but other
years/models may require parts from newer years/models of Civics to be fully
emissions compliant.
PICKING THE CHASSIS
For starters, Hasport, one of the best-known names for Honda swap parts and engine mounts, has engineered the K-series swap into the 1996-to-2000 Civic chassis. Any of the Civics (except a Civic that has a Contnuously Variable Transmission, CVT) made in these years can accept a K-series engine. A Civic with an auto tranny will work too, but the kit is made to drop in a manual transmission K-engine. You'll have to add the clutch pedal yourself.
The leanest, meanest car for speed would be the 1996-to-1997 CX hatchback. It has the lowest weight, least emissions control, a relatively rigid body (since it has no moonroof), and is still relatively available. Next would be a coupe, like an HX, but even a 2000 sedan with it's 300 extra pounds will suddenly wake up, especially if you drop in a torquey K24.[/u]
PICKING THE ENGINE
There are several versions of the K-series. Any of them will fit, but some are better than others. The K20A2 powers the RSX Type-S. It's the best of the U.S. engines, mainly because it has the real VTEC, with high- and low-rpm lobes for both intake and exhaust valves, as opposed to the sissy eco-version that only acts on the intake cams and has no high-rpm lobes. The A2 also packs the highest compression, is built to withstand higher revs and comes bolted to a six-speed.
Unless it's cheap, a K20A3 engine from a Civic Si or base RSX is probably one to skip. You can beat it with a B20 VTEC and save the trouble of the wiring harness. It'll go in just like the K20A2 shown here, but unless being different means more to you than being better, why bother?
The K24s from the Accord Element and CR-V are all basically the same, bt different intakes and emissions components can complicate things. the Accord and Elements have the most emissions control stuff. The CR-V is called a "light-trc" by the EPA and will have less crap to hook up, notably EGR. All California cars will have more emissions crap. Consider a K24 for a swap because it will have great torque, responds well to turbocharging and paves the way to a future upgrade with an RSX Type-S or TSX head.
That leaves the K24A2 from the TSX or the JDM ITR engine, called simply the K20A. The JDM K20A is the best OEM version there is, with 20 more factory hp and a limited slip. The TSX us so new you likely won't see one in a yard for some time. The TSX also uses an electronic throttle that could cause other problems. But either of these engines follows the same installation as laid out here.
Code:
[u][B][SIZE=3]Parts Table[/SIZE][/B]								[/u]
There are some things that must be custom if you do this swap. Hasport
sells nearly all of them. Some other parts are from Honda but are not original
to the EK.
[u][b]CUSTOM PARTS									[/b][/u]
Engine mounts
Driveshafts. No OEM units work exactly
Wiring harness
Exhaust header
A/C hoses (optional)
Air intake (aftermarket units are easliy modified)
Fuel pressure regulator
Metal clutch tubing from master cylinder to rubber tubing on K trans
[u][b]HONDA PARTS NOT FROM YOUR CAR							[/b][/u]
2002-and-up Civic Si throttle cable
1990-1997 Accord shifter box or RSX shifter box
1994-2001 GS-R radiator hoses
2002-and-up Civic Si idler pulley (goes where power steering pump was)
PICKING THE TRANSMISSION
If you're polling the yards for complete swaps, you may not have a choice, but there are some diamonds out there. The best of them would be the six-speed from the RSX Type-S, Japanese Type-R or TSX. Either is good, with the TSX being geared for the torque of 2.4-liters and the Type-S and Type-R geared for high-revving powerbands.
It's all about teh other trannies that present you with choices. There are no CR-V two-wheel-drive manuals, but the Element has some short (high numerically) gears. It might make for a nice, all-motor gearbox. Next is the Civic Si. Nearly and exact match for the RSX, it has lower first and second gears, but a higher final drive. The Accord tranny is about fuel economy. It's the easy choice for turbo application though, where short gears just mean wheelspin. See the transmission ratios table for all the details. Gears and final drives of all teh five-speed boxes are interchangeable, as are the six-speeds. But you can't swap parts between five-speeds and six-speeds.
Code:
[b][u][SIZE=3]K-series gear ratios[/SIZE]											[/u]
		Accord		TSX		RSX-S		RSX		Element		Civic Si
1st[/b]		3.267:2		3.267:1		3.267:1		3.267:1		3.533:1		3.062:1
[b]2nd[/b]		1.769:1		1.88:1		2.130:1		1.880:1		2.042:1		1.769:1
[b]3rd[/b]		1.147:1		1.355:1		1.517:1		1.212:1		1.355:1		1.212:1
[b]4th[/b]		0.872:1		1.028:1		1.147:1		0.921:1		1.028:1		0.921:1
[b]5th[/b]		0.659:1		0.825:1		0.921:1		0.738:1		0.825:1		0.738:1
[b]6th[/b]		0.659:1		0.738:1
[b]Final Drive[/b]	4.389:1		4.700:1		4.389:1		4.389:1		4.765:1		4.764:1
ENGINE REMOVAL AND PREP WORK
This is kinda old hat by now. The D-series engines that orginally came with these cars are tiny little guys that come out easily. A lift makes things easier since Honda motors comoe out the best from the bottom.
When you're buying your K motor, make sure to get everything attached to the engine, including the engine wire harness and the engine charging harness (battery cable and alternator wires), since it's a separate piece on K-engines. The batteries are different places in the K-powered cars and you're going to need its charging and power distribution harness for the EK.
The other must-haves are the ECU, an original key and the transponder from the steering column. Since 2000, Honda has built all it's cars with a coded key and transponder system as an anti-theft device. ECUs are matched to keys and can't be reprogrammed without a lot of documentation and an understanding dealer.
COOLING SYSTEM
This one is a bit of a bugger. Our EK uses an aftermarket radiator moade for an RSX (you can use the stock RSX unit as well). The stock lower mounts have to be cut off and mounted lower down, but it's very effective and uses stock RSX hoses. The old EK radiator's fan switch and temp sensor had to be moved when we did this as well (and are still needed if you use your EK radiator).
This setup means no AC/ without the RSX condensor. Another option, if you want A/C, is to make the EK radiator and the A/C condensor switch places (they sit side-by-side, not one in front of the other like most cars). In the stock location, the EK radiator's upper outlet hits the K-series intae manifold. For hoses you can use 1994-to-2001 GS-R upper and lower hoses. the lower hose will require some creative trimming to fit properly.
NOFX
I'm NOT eran!
The A/C compressor from the will work with the EK's condensor, but yo'll have to get custom hoses made. Any good A/C shop should be able to do it. If you don't care about A/C and didn't get the RSX radiator, then just move your EK's radiator to the driver's side and plug the gaping condensor hole so air will actually go through the radiator.
This car didn't have A/C and so the above suggestions are I-think-so engineering. The K-series compressor will certainly wor with the E's condensor and it will also work with the condensor from the K-series donor car. The question on that one is, "Can yoiu make it fit?"
POWER STEERING
Sorry, this is a no-go as of yet. The problem is that the pulley sticks up too high to clear the hood. Even when you cut hood support beams, there's not enough room. Likely, a carbon-fiber hood company will make a K-series hybrid hood soon. For now, you can just loop the in and out hoses on the steering rack together and get a hell of a workout. You will also need to intall the idler pulley from an EP3 (2002-and-up Civic Si) to tae the place of the power steering pump.
MOUNTING THE ENGINE
The mounts fit a K20 or the 20mm taller K24. If you're installing a K24, to get the stock hood to shut, some of the reinforcing beams need to be trimmed. Be careful not to cut too far. If you install a K20, you won't have to do this.
Whenlowering the car onto the engine (remember, that's the easier way) line up the left and right mounts first, getting a few threads into those, but leaving them loose. Then get the top bolt off the rear mount. With the lower bolt out, put in the driveshafts. The lower bolt on the rear mount rotates the motor and can make getting the driveshafts in much tougher.
DRIVETRAIN HOOKUP
Damn, the bills are piling up fast on this swap. But no one ever said that being the first to do a project would be cheap or fast. Your EK needs new axels, because none of them fit exactly. The Civic Si is the closest fit but still come up short on one side. The Driveshaft Shop custom-built the axels on this car, but Hasport will have both 250- and 400-hp versions in stock, with 525- and 800-hp models available by special order.
Next is the shift linkage. The EK uses big rods under the car and the K motor's tranny uses cables on top of the floor - not to mention the transmission is on the other side of eth car. In the world of Honda accidental parts compatibility, the shifter mechanism (the shifter arm and the base it's attached to) from a 1990-to-1997 Accord is what you need, plus the cables from the K tranny.
The installation problem here is the EK's transmission hump. Sitting the new cable shifter mechanism on the hump makes the shifter so tall, the factory console won't cover it. A solution is to mount it under the car. Doing so means making an enclosure for the mechanism so it's not exposed to the elements. Hasport enclosed it with sheet steel and it worked perfectly. Inside the car, all you see is the stick coming up jst lie stock. Cables were routed under the car as you would on an H22 swap.
The shifter mechanism from any RSX, TSX or current-model Accord will work too, but it's very tall. Enclosing it and pulling it under the car may not leave enough exhaust clearance. If you use this you'll have to be creative or skip the stock center console (perfect for racecars).
Finally, you'll probably need a throttle cable from a new Civic Si (EP3). The one in you Civic may or may not be long enough.
FUEL SYSTEM
This is either pretty simple if you live in non-California-emissions state or really tough if you're in California. Most of it has to do with fuel vapor control. Take a look in the manual at all the controls on the car your K engine came from and you can see about matching them up with your Civic chassis. The 1999-and-2000 cars may have all the matching controls, but certain models may not. The 1996-to-1998 cars will be tougher to match and may require pulling parts from other Civics.
If you don't have them and must put them in to pass emissions, you can probably find a newer sixth-gen chassis atht has all teh corresponding parts. An example would be a fuel tank pressure sensor. This is on all K-series cars and 1999-to-2000 Civics, but not our 1996. You have to look at all the emissions control stuff on the K-series donor car and match it part for part to your car if ou want to pass the California smog test or any state that follows California's rules.
The other challenge is the fuel return system. Your EK Civic has one, but the K-series engine doesn't, plus the K-series operates at a constant fuel pressure, rather than followinf the intake manifold pressure liek the EK's engine did. An adjustable pressure regulator does the trick - just set it to the pressure in your K-series manual.
Fuel come into the regulator from the filter, pressure is set and goes out to the fuel rail. Excess fuel from the regulator is sent back to the tank via the EK's return line, which is attached to the second output of the regulator. Mounting the regulator on the firewall close to the fuel filter means just a couple of custom hoses. Don't hook up a manifold vacuum line. It will freak out the K-series ECU.
INTAKE
Obviously, short-ram intakes designed for the K-series are going to be the easiest. But they aren't very good to begin with, since they typically put the air filter on top of the hot transmission. A better way is to work some custom cold-air piping into the pocket in front of the driver's tire and the bumper. Just like an EK cold air, but on the other side. As this swap becomes more common, companies will likely mae these, just as AEM does for B- and H-hybrid swaps today.
EXHAUST
This is now on the firewall side. Because of the very differnt crossmember on the EK, the stock exhaust won't work, nor will any aftermarket exhaust. Hasport has long tube headers available that terminate into a 2.25-inch collector. You can use the stock EK cat and exhaust, but will need to shorten the B-pipe.
The O2 sensors on K-series engines are unique. Be certain to get at least the front or first sensor when you buy the engine. The catalytic converter is useless. It contains another 12 inches of pipe before the cat, but the front O2 sensor is a full wideband unit and the ECU expects readings from it, not the narrow band sensor taht came with the EK.
THE WIRING
If you thought it was tough getting the right engine with all the right parts and then getting it in the car, grab a drin and sit down.
Realists, add $399 to your budget, send the stock EK harness, the K engine and charging harnesses to Hasport as a core and get back the plug and play version. More time than money? Here goes.
Order the service manual and electrical trouble shooting manual for your chassis and the year and type of car your engine came from at www.helminc.com. Helm makes all teh OEM manuals for Honda and they're cheaper than at the dealership, even with a shop discount. With all four of those in hand, you can follow along. These notes are for a 1996-to-1998 chassis; 1999-or-2000 models may be different.
Here are your biggest challenges: The EK has a single harness for the engine and for the charging system. The K has separate harnesses. The EK has a conventional dash and the Ks use a multiplex (multiple signals sharing one wire) system to drive the spedo, tach, water temp and more. The EK has relays that operate differently than a K. The K's engine harness comes through the passenger's side of the firewall with all its wires, the EK has most of its wires in the same place, but there is one critical plug at the driver's-side shock tower.
There are also signals that are in the EK cabin harness that need to go into what would be the K's engine harness. Some things, like engine temp, have to be wired directly into the dash because, although it gets into the K's ECU, there isn't a separate output wire. The water sensor on your stock radiator will need to get wired directly to the dash via the driver's side shock tower plug (see wiring charts).
Most importantly, make sure to egt what the K manual refers to as the E-plug on the K-series ECU. When the junyard guys send the ECU, just have them cut it with as much wire hanging from the E-plug as possible. They likely will because there are only three plugs for the ECU and the other two are on the engine harness.
ECU
You need the ECU, key and transponder that match your new K engine. However, Hondata does have a reflashed RSX, RSX Type-S or Civic Si ECU available with dyno-proven results. It also has a fully programmable version based on the RSX Type-S ECU that gives you control of ignition, fuel, i-VTEC, idel, redline, nitrous control, boost and more.
If you want the Hondata, the best way to go is the fully programmable unit because it's the only one that can disable the error codes associated with missing emission controls. Be sure to budget at least $400 to $500 for dyno tuning. Hondata will also sell you a brand-new EC if you're moving froma non-Hondata compatible ECU (Accord, Element, CR-V) to a programmable or reflashed unti.
Hasport has ECUs with the immobilizer removed, but you'll be expected to provide full documentation (including VIN numbers) of where you obtained you swap engine. If you source your own ECU, you'll need the matching VIN number as well or a new ECU receipt. The purchaser's info will be shared with law enforcement upon request.
NOFX
I'm NOT eran!
Code:
[U][B][SIZE=3]REWIRING EK PLUG C101 AT DRIVER'S-SIDE SHOCK TOWER						[/SIZE]
COLOR/PIN#	COMES FROM ENGINE SIDE				DESCRIPTION										[/B][/U]
Blk/Wht 1	Air/fuel relay, VSS, alternator, EVAP		Provides power for multiple devices
Yel/Red 3	Oil pressure sensor				Routes signal for oil pressure to gauge
Wht/Blu 6	Charging system					Provides voltage from alternator for charge light
Yel/Grn 7	NEW engine coolant temp sending unit		Temp sender is added to drive dash gauge directly
Blu 8		K ECU Plug E, pin 26 ECU ignition test signal	Tach signal nromally comes from dash, must come from ECU.
Blk/Wht 9	Starter						Routes starter signal from ignition switch to starter
[u]Blk/Yel 10	Coil power junction connector			Routes power from ignition switch to coils		[/u]
[COLOR=Red]IF A PIN IS NOT SHOWN, IT IS NOT USED[/COLOR]
Code:
[U][B][SIZE=3]REWIRING PLUG C101 ON K ENGINE HARNESS[/size]
COLOR/PIN# 	GOES TO 					COMES FROM (ENGINE SIDE)		DESCRIPTION[/b]						[/u]
Grn/Wht 1	EK C131 pin 14, reverse lights			Transmission Reverse switch		Turns on reverse lights
Yel 2		EK C131 pin 15, reverse lights			Transmission Reverse switch		Turns on reverse lights
Wht/Grn 3	EK C131 pin 8, speedometer			Vehicle Speed Sensor			Provides signal for speedometer
Green 7		EK C131 pin 6, radiator fan relay		NEW radiator fan switch			Turns on radiator fan
Blk/Yel 9	EK C101 pin 1, +12 volts			Alternator, VSS, AF Relay		Power for multiple devices
Blk/Wht 20	EK C101 pin 10, coil power			Ignition coils				Power to ignition coils
Blk/Wht 16	EK C101 pin 9, ignition				Starter					Start signal from ignition to Starter
[u]Yel/Red 18	EK C101 pin 5, oil pressure warning		Oil pressure sender			Signal for Oil pressure wanring light
[b]These wires from K ECU plug A go over to the K's C101 plug and terminate. Take then out of the K's C101 plug and connect to the relay pins.		[/b][/u]
Red 19		air/fuel sensor pin 1				A6 ECU					Air/fuel sensor input
Blk/Wht 10	air/fuel sensor pin 4				A1 ECU					Air/fuel sensor heater control
Red/Yel 13	air/fuel sensor pin 2				A16 ECU					Air/fuel sensor ground
Yel/Blk 14	new main relay 1 pin 87				A2 & A3 ECU, Injectors, others		Power for IG1 & IG2 at ECU and power for multiple devices
[u]Wht 15		air/fuel sensor pin 3 & A/F relay pin #87	A22 ECU					Air/fuel sensor reference voltage			[/u]
Code:
[U][B][SIZE=3]WIRES INTO K SERIES ECU PLUG 'E'[/size]
COLOR/PIN#	COMES FROM ENGINE SIDE		DESCRIPTION[/b]							[/u]
Grn/Yel 1	Main relay 2 pin #86			Immobilizer cut on fuel pump, drives main relay
Brn/Yel 3	Data link connector pin #5		Ground for ECM control circuit
Red/Yel 7	Main relay 1 pin #86			Drives main relay 1, power source for check engine codes
Orn 8		Air/fuel sensor relay pin #86		Drives air/fuel sensor relay
Yel/Blk 9	Splice into wire at main relayPin 30	Ignition 1, detects ignition signal
Grn/Red 15	EK C131 pin #16				Electronic load detector signal
Red 18		EK C131 pin #19				Drives A/C clutch relay
Wht/Blk 22	EK C131 pin #17				Brake pedal position switch signal
Lt Blu 23	Data link connector pin #7		Sends and receives scan tool signal
Blu 26		EK C131 pin #8				Outputs enging speed pulse
Brn 29		Data link connector pin #9		Detects service check signal
Red/Wht 30	Data link connector pin #12		Detects write enable signal
[u]Grn/Orn 31	EK C131 pin #8				Drives check engine light in dash			[/u]
NOTE: datalink or OBDII plug connections are optional, the car will run
without them. You may not pass emissions without a working OBDII plug.[/COLOR]
Code:
[U][B][SIZE=3]MAIN RELAY #1															[/SIZE]
PIN #	CONTAINS						DESCRIPTION											[/B][/U]
85 Blu	+12 volts constant from your chassis' main relay plug		Your chassis' relay plug, gets voltage from fuse 31
30 Red	+12 volts constant from your chassis' main relay plug		Input side of the switched output of the relay
86 Yel	Signal from K ECU plug E, pin 7					Activates the relay, controls ignition
87 Blk	Signal from K ECU plug A, pin 2 and 3				Output side of the switched output of the relay, goes to main relay 2
[U][B][SIZE=3]MAIN RELAY #2															[/SIZE]
85 Blu	+12 volts from pin #87 main relay 1				Power for main relay 2
30 Red	+12 volts constant from your chassis' main relay plug		Input side of the switched output of the relay, gets power from fuse 12
86 Yel	Signal from K ECU plug E, pin 1					Activates the relay, controls immobilizer fuel pump
87 Blk	Fuel pump via main relay connector				Output side of the switched output of the relay, goes to power the fuel pump
85 Blu	+12 volts constant from your chassis' C101, pin 1		Power for air/fuel relay
86 Yel	Signal from K ECU plug E, pin 8					Activates the relay, controls ignition
87 Blk	Signal from K ECU plug A, pin 22 & air/fuel sensor, pin 3	Output side of the switched output of the relay, air/fuel sensor reference voltage
TEST DRIVE
If you're still excited about this swap with all it's complexity and mass of odd or custom parts, then you'll love the result. If it's 160 hp from a K20 or the super low-end torque of a K24, this is a great swap. The lucky few who get K20A2 motors will really love their new EKs.
green ej8
diamond member
wow amy you deserve the biggest (insert what you'd like) award that agreat post
NOFX
I'm NOT eran!
I had posted this awhile back, removed it, and it was reposted by a mod. I figured I'd reformat it so it was easier to read though and post it back up.
racerx661
certified pervert
very nice lil post..this should help the few and brave
joba356
Quick question, Can the same rewiring procedure be used on a EG, cause im doing a K swap on my EG and this is the only Rewiring explanation i have found but its for EK, does it have Mayor diffrences?
NOFX
I'm NOT eran!
I'm not really sure. I'd advise you to post a new thread on it though. We have members who have done the swap you're talking about.
Jrjr
I have that one and it is sitting on my garage workbench open to the page wating to be used lol
DigitalShift
There isnt really any "rewiring procedure". Things you need in order for your K swapped car to crank:
1. K20A engine harness
2. JDM Type R ECU, or KPRO (the stock type S will NOT work)
3. K20 sub-charging harness
4. conversion wiring harness
5. basic wiring knowledge
If have those things your K swap car will crank and run. It's VERY simple. It's pretty much plug and play with the exceptions of running a few wires to your coolant and fan sensors in the engine bay.
3DScott
OMG! Whats funny about this thred is i was going to ask you if it's hard to do this. lol
How much does a K series motor run? Plus install?
NOFX
I'm NOT eran!
A K-series motor doesn't belong in a 6th gen, at least they weren't designed to go together. K-series motors came about after the 6th gen Civic.
Though the price of the motors are falling, you still would have to buy custom parts to install this motor into your car. You can't do what you can do with many other swaps and just get parts from other Integras, Civics, and CR-Vs.
Also, I'd recommend insuring that swap and all it's parts in full. Otherwise you're going to cry really hard if it get stolen. Because, no, your current insurance for your car stock does not cover the aftermarket parts you put onto the car. That means even right now if somene stole your wheels, you're out of luck. Finding someone to insure that swap in your car would be much more difficult than finding regular insurance though. I know Esurance will insure up to $2000-3000 in aftermarket parts, but with a motor swap in particular that will add up t far more than that in no time.
I also don't know anyone locally who knows that much and is reliable enough to do that swap into a 6th gen. I'd recommend you look into B and H series motors. D-series motors, as you already know, can also be swapped into your car.
SEARCH FOR:
k-series
K20 EK9 Build up, tons of pics! (this is a 6th gen hatch - the former DAP we told you about)
INFO: K-Series Into EG/EK/DC (more info on swapping)
difference between a k20 and b18 ?? (this guy has a 5th gen, though the information should not just be for 5th gens)
K and H Comparison Help : ) (though this first post in that thread is asking about putting it in a 4th gen though I dont' think the info is just for 4th gens)
K Series Mania!! (photos of K-series motors in a few cars that weren't meant for them)
NOFX
I'm NOT eran!
Scott won't be installing it himself.
