Del Sol seat swap in a 6th gen.
http://members.tripod.com/gamby123/id33.htm
Installing a Rear Disc Brake Conversion 96-up Civic
http://www.geocities.com/importpro2001/installingrearbrake.html
Honda Parts Diagram
http://www.hondaautomotiveparts.com/auto/jsp/mws/catdisplay.jsp
Do-it-yourself air-fuel ratio meter
http://www.aces.edu/~gparmer/efi/temp/wb/guide.html
Car Stereo Install Help
Install Dr.
Turbo And Other Related Links
http://www.honda-tech.com/zerothread?id=67146 -oil return
http://www.honda-tech.com/zerothread?id=109160 -oil return line setup
http://www.honda-tech.com/zerothread?id=114490 -oil return line parts
http://www.honda-tech.com/zerothread?id=71999 -where to weld oil return
http://www.honda-tech.com/zerothread?id=119100 -oil return line
http://www.honda-tech.com/zerothread?id=119539 -oil pan welding
http://www.honda-tech.com/zerothread?id=119715 -oil pan welding
http://www.honda-tech.com/zerothread?id=118687 -oil grade to use
http://www.honda-tech.com/zerothread?id=118694 -ft for oil feed line
http://www.honda-tech.com/zerothread?id=118807 -oil feed line
http://www.honda-tech.com/zerothread?id=119681 -oil feed line
http://www.honda-tech.com/zerothread?id=93550 -part for oil feed line
http://www.honda-tech.com/zerothread?id=114436 -where to buy brass t for feed line
http://www.honda-tech.com/zerothread?id=126335 -oil t question
http://www.honda-tech.com/zerothread?id=125438 -another place to buy oil lines
http://www.honda-tech.com/zerothread?id=131447 -oil feed line an/npt connector ?
http://www.honda-tech.com/zerothread?id=134078 -feed diagram
http://www.honda-tech.com/zerothread?id=133948 -oil bpst fitting again
http://www.honda-tech.com/zerothread?id=144586 -oil feed line restrictor
http://www.honda-tech.com/zerothread?id=155510 -oil leaks
http://www.honda-tech.com/zerothread?id=158018 -oil feed 3' better
http://www.honda-tech.com/zerothread?id=156571 -oil pan bolts
http://www.honda-tech.com/zerothread?id=170223 -oil pressure readings
http://www.honda-tech.com/zerothread?id=168084 -oil feed fitting
http://www.honda-tech.com/zerothread?id=131450 -oil feed diagram
http://www.honda-tech.com/zerothread?id=195068 -oil pressure
http://www.honda-tech.com/zerothread?id=122635 -drag 3 (to) coolant line?
http://www.honda-tech.com/zerothread?id=116891 -closed loop turbo info
http://www.honda-tech.com/zerothread?id=119724 -drag 3 turbo fitment (filing block)
http://www.honda-tech.com/zerothread?id=119690 -vacuum source
http://www.honda-tech.com/zerothread?id=94820 -closed loop
http://www.honda-tech.com/zerothread?id=120814 -Drag3 downpipe
http://www.honda-tech.com/zerothread?id=120867 -Drag3 + Tial connection
http://www.honda-tech.com/zerothread?id=118699 -wastegate vacuum line
http://www.honda-tech.com/zerothread?id=118767 -feul pump for drag 3
http://www.honda-tech.com/zerothread?id=121442 -fittings (brass T on block)
http://www.honda-tech.com/zerothread?id=123326 -blow off valve tightening
http://www.honda-tech.com/zerothread?id=123925 -catalytic converter removal o2 sensor
http://www.honda-tech.com/zerothread?id=124474 -'burning' in the turbo + blow off valve ?
http://www.honda-tech.com/zerothread?id=124580 -drag 3 manifold boost spike issues
http://www.honda-tech.com/zerothread?id=124662 -drag 3 tial fitment
http://www.honda-tech.com/zerothread?id=151845 -closed loop dump tube
http://www.honda-tech.com/zerothread?id=155616 -flexpipe issue
http://www.honda-tech.com/zerothread?id=159889 -blow off valve adjusting/cleaning
http://www.honda-tech.com/zerothread?id=163453 -egt probe tapping
http://www.honda-tech.com/zerothread?id=167329 -o2 sensor bung
http://www.honda-tech.com/zerothread?id=170498 -don't use tial gasket
http://www.honda-tech.com/zerothread?id=175270 -intercooler direction
http://www.honda-tech.com/zerothread?id=175277 -drag bolts suck
http://www.honda-tech.com/zerothread?id=206376 -bov greddy type s (loose)
http://www.honda-tech.com/zerothread?id=120548 -hondata install (solder stuff)
http://www.honda-tech.com/zerothread?id=98092 -hondata install heiarchy
http://www.honda-tech.com/zerothread?id=121859 -hondata info on pumps
http://www.honda-tech.com/zerothread?id=117300 -spark plugs
http://www.honda-tech.com/zerothread?id=156273 -spark plugs (2)
http://www.honda-tech.com/zerothread?id=116886 -changing plugs
http://www.honda-tech.com/zerothread?id=117326 -flexpipe for good price
http://www.honda-tech.com/zerothread?id=117733 -injectors, 440 or 550
http://www.honda-tech.com/zerothread?id=119569 -guage for autometer
http://www.honda-tech.com/zerothread?id=119591 -autometer guages
http://www.honda-tech.com/zerothread?id=121452 -aero fpr
http://www.honda-tech.com/zerothread?id=119884 -best FPR?
http://www.honda-tech.com/zerothread?id=118885 -place to buy aem fpr
http://www.honda-tech.com/zerothread?id=122590 -(installing) aeromotive fuel regulator
http://www.honda-tech.com/zerothread?id=86051 -removing/installing intank fuel pump
http://www.honda-tech.com/zerothread?id=120889 -profec b install
http://www.honda-tech.com/zerothread?id=116651 -Radiator fans
http://www.honda-tech.com/zerothread?id=119819 -diff between mechanical/electrical gauges
http://www.honda-tech.com/zerothread?id=117513 -turbo XS boost controllers and tial wastegates
http://www.honda-tech.com/zerothread?id=122396 -block guard
http://www.honda-tech.com/zerothread?id=107030 -rc 440 injector polarity
http://www.honda-tech.com/zerothread?id=82211 -rc 440 after hondata install
http://www.honda-tech.com/zerothread?id=121452 -aeromotive fpr part #
http://www.honda-tech.com/zerothread?id=125639 -hks ssbv clip
http://www.honda-tech.com/zerothread?id=153531 -more hks bov install
http://www.honda-tech.com/zerothread?id=125852 -carsound cat part #
http://www.honda-tech.com/zerothread?id=92570 -turbo timer relay
http://www.honda-tech.com/zerothread?id=128321 -turbo timer wiring
http://www.honda-tech.com/zerothread?id=132485 -radius rods
http://www.honda-tech.com/zerothread?id=63095 -rear seat removal
http://www.honda-tech.com/zerothread?id=133644 -injector fitment
http://www.honda-tech.com/zerothread?id=104940 -thermal to cat issues
http://www.honda-tech.com/zerothread?id=136680 -egt guage stuff
http://www.honda-tech.com/zerothread?id=137223 -which runner to tap for egt
http://www.honda-tech.com/zerothread?id=55987 -aem fpr against strut bar
http://www.honda-tech.com/zerothread?id=139706 -tools to carry
http://www.honda-tech.com/zerothread?id=140003 -base fuel map
http://www.honda-tech.com/zerothread?id=140774 -bleeding coolant
http://www.honda-tech.com/zerothread?id=156073 -js safeguard
http://www.honda-tech.com/zerothread?id=168470 -js safeguard, who is using
http://www.honda-tech.com/zerothread?id=160428 -summit part
http://www.honda-tech.com/zerothread?id=170160 -9psi, raise static fuel + retard timing
http://www.honda-tech.com/zerothread?id=170821 -wires to tap for guages
http://www.honda-tech.com/zerothread?id=171397 -c clamp pliers for hks bov
http://www.honda-tech.com/zerothread?id=171314 -EGT temps
http://www.honda-tech.com/zerothread?id=166449 -vacuum sources
http://www.honda-tech.com/zerothread?id=175335 -assembling an fittings
http://www.honda-tech.com/zerothread?id=176725 -oem fan clearance - move to right
http://www.honda-tech.com/zerothread?id=193263 -greddy profec b
http://www.honda-tech.com/zerothread?id=85987 -installing rc injectors
http://www.honda-tech.com/zerothread?id=106033 -matching wires rc injectors
http://www.honda-tech.com/zerothread?id=133644 -fitment of rc injectors
http://www.honda-tech.com/zerothread?id=107030 -polarity does not matter
http://www.honda-tech.com/zerothread?id=154935 -once installed
http://www.honda-tech.com/zerothread?id=159623 -tips to install
Honda Parts Diagram
Install Dr.
