Eugene Cartwright
My 2012 civic starts up then idles good , then in less then a minute dives in and out but my rpm doesn't move , some help please ??
The rpm doesnt moves the engine seems to want to cut out but doesnt keep just dives in and out and only when i to a stop.I changed your title to something helpful as "help" doesnt say anything about your issue to draw in assistance.
With that said, its to your benefit to provide further details. Explain what you mean by "dives in and out". Do you mean the RPMs fluctuate up and down but the needle doesnt move? Does this happen in neutral only or while driving? Was anything done to the car recently that could potentially be affecting this?
YesIs the check engine light on?
Can you be a little more clear on this? What do you mean by "dives in and out"?The rpm doesnt moves the engine seems to want to cut out but doesnt keep just dives in and out and only when i to a stop.
Get an ODB2 scanner and plug it into your car. It will tell you why the check engine light is on. There is a good chance this code holds key details into why your car is acting the way it is.
Can this be a idling problem ?Can you be a little more clear on this? What do you mean by "dives in and out"?
Also confusing to me it seems as if it want to cut out but doesntConfusing^
What is diving in & out if your engine rpm is steady?
My radio and display screen isnt coming on niether is the computer scanner what is it now ?There is clearly a communication and language barrier issue here. Im still having to edit your posts because you are not making an effort to repky clearly or understand how posting works.
Eugene, if you cant explain yourself more clearly AND ANSWER THE QUESTIONS YOU HAVE BEEN ASKED then it is very hard for us to help you. We are confused because we dont understand what you mean when you say "diving in and out" and you havent explained it any differently or with any detail.
As for a "jerk" when the car is already stopped, that could be caused by several things. Again, without clearly explained details we cannot help you.
I agree that you should get the Check-Engine Light code read then post the codes here and research what it means.
