is it possible to make EG shocks fit in a EK?
rayej8
so will these shocks actually fit a ek because my cuzin gave me some brand new kyb shocks that he was goin to use but he has itr lcas on his eg so it didnt fit ive read around and said it should but ive also read about clearance issues for rear shocks due to ek lcas being thinner???
does anyone know about this?
if i get aftermarket lcas will it help mount these shocks a lil better?
Kensai
You can either get EG/DC/Aftermarket LCA's or just trim your bushing like quarter of an inch on each side in the back.
I'm not sure on the exact number but you can just measure them I guess, but you can definitely make it work!
rayej8
i think the lcas from a eg/dc are shorter than the ek i think the ek ones are longer
yea i was thinking about drilling the hole a little bit wider ill see wat i do hopefully i make it work lol
thanks
Kensai
Err it's opposite, you will need to trim EG/DC lca bushings to fit EK shocks on them, the other way around you'll need to add washers/wider bushing.
Inorder to get EG shocks to fit into an EK the fronts work without any problem as they are the same.
The rear shocks however are different on how it mounts on the EK. EG arm bushings are longer which is true, but the distance from the top of the arm to the middle of the bushing is also shorter since the arms are cast.
EK arms on the other hand are pressed steel, first difference is the shorter shock mount bushing and yes you can add washers to make it work. However one thing that no one bothered to mention is that when you mount the EG shock onto the EK arm you will find that in order to make it you have to jack up the arm because the bottom portion on the EG shock is shorter which binds with the EK arm.
Does it work of cause but if you jack up the car the shock will hit the arm acting as a limitter which can be a bad thing or good depending on the situations.
How I know because I am using it on my EK, I cut part of the shock mount off to allow for a bit more travel. It works but thought you should know.
And to make EK shocks to fit the EG I would not suggest grinding the bushing as this creates trememdous heat which will damage the rubber part of the bushing. You can widen it by taking the 32mm axle nut and hammering it wider then compress it to fit the bushing which would also work. Did this on my CRX before, good luck. You might blow out your shock if you slam your car since the EK shock is a bit taller.
rayej8
ok koo thanks again
and on this quote at the end it says that if u slam it the shock can blow how i sthat possible if the angle of the lca will b diff than stock height??
